import wizard for PMDG 737
Hello ,
I bought and installed GIT for MSFS2020
( I know the product for Xplane )
when I click on '' import wizard'' I have to look for the file PMDG737.zip but how to find it ???
thank you for your help
Roland
w10
MSFS updated
PMDG 737-900
    maybe it is not necessary to import a file here is what I have see photo but the MCP don't work
  • GIT automatically configures for use with the PMDG. Make sure you have ENABLED the MCP Pro in GIT. Also check in the log for an entry confirming the PMDG SDK is ok.
  • Hello
    ''Make sure you have ENABLED the MCP Pro in GIT.'' ok the picture above
    "Also check in the log for an entry confirming the PMDG SDK is ok." I don't know where to see this message
    see the log texte
    thanks for your help
    best regards
    Roland
  • OK, I suspect the PMDG SDK has not been automatically enabled by GIT. Can you check the following with GIT and FS not running:
    To enable the data communication output, you will need to open the file
    737_Options.ini that is located in the 737 persistent storage folder.
    For Microsoft Store distribution, this folder is located at
    %LOCALAPPDATA%\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\Lo
    calState\packages\pmdg-aircraft-737\work\.
    For Steam distribution, this folder is located at
    %APPDATA%\Microsoft Flight Simulator\Packages\pmdg-aircraft737\work\.
    Once this folder is open, add the following lines as required to the bottom of
    the file:
    [SDK]
    EnableDataBroadcast=1
    Try again, if still no good, check the above again and see if it has been turned off.
  • Hello
    ok I did it two times
    the only difference is that this green point dot is now blinking
    thanks
    Roland
  • and how find the last version of driver Goflight ? i have not it
    Roland
  • Ok, blinking is good, that means the SDK is enabled. Do the rotaries work on MCP PRO and is it only the displays not working? If so does the Identify button on the MCP Pro tab light up the MCP Pro?
    The drivers are available in the downloads section of the website.
  • Hello ,
    so today everything seems to work on the ground I have not yet tried in flight ( I will do a flight tonight ) but all display and all buttons Efis and MCPpro work!
    so I think it's ok without having done anything else
    thanks Steve for your precious help
    bests regards
    Roland
    What drivers at which website? (ABOVE)
  • This website and they are GoFlights own driver software.
