Manuals for GIT
Is there a manual for Pollypot for X-Plane. I have been trying for four days to break the ice and have gotten nowhere. I have installed it correctly, I think. I get the GoFlight Interface to come up and it saves a xml file but I don't know where to put it. I have so many basic questions such as that. I can read a manual but I can't find one.
Also, for the beginner (that is I for sure) it says to import the downloaded zip file, but isn't one for the C-47. Then what? I am trying to get the LGT2 installed in the VSKYLABS_C-47. Anyone able/willing to get me started?
stantona@cox.net
stantona@cox.net
If no config to download you need to manually configure. See manual.
Alex
Finally I have made some progress to be able to say something positive and ask you something that might make sense.
I have discovered that if I set up the 'GoFlight Interface Tool', everything seems to work as long as I leave it running while I run the simulator. I thought the 'Tool' was to make the 'xml' file in the 'GIT Plugin' folder, then close the 'Tool' and the 'xml' file was the plugin.
So, if the latter is true, what do I do now to close the Interface Tool and still have the plugin work when I boot up the simulator?
Am I making this clear enough so that you understand the question?
Thanks for your help.
Alex
