XP 12 GIT issues
It mostly works. Altitude, Vertical Speed, and Right course knob do not interface with XP. GIT v3.0.2.0, XP 12.05r1.
WinSock: Connection Failed: No connection could be made because the target machine actively refused it 127.0.0.1:27015
LUA Processor: Connect Exception - Unable To Connect!
BespokeEventProcessor: Task Failed RunLUA(D:\Documents\GoFlight Interface Tool\LUA\global.lua)
BespokeEventProcessor: Task Failed RunLUA(D:\Documents\GoFlight Interface Tool\LUA\b738\global_aircraft.lua)
I did change localhost to my ip address, still reports this. Where do we go from here? MCP Pro works just fine in MSFS.
  • I have narrowed this down to the aircraft config files that are downloaded here. I have tried every one that is of the 737 type. Each one does not have one or more knob interaction. Although you can see the green buttons flicker when you rotating them. So now I will have to see I there is a way to configure the Zibo on my own. Any help would be appreciated.
  • GIT cannot talk to the GIT X-Plane plugin. Either the plugin is installed in the wrong place (you are prompted for the location during GIT install), or your firewall is blocking communication or you need to configure Documents\GoFlight Interface Tool\Lua Config.txt changing "localhost" to your actual ip address (if you do this make sure GIt and X-Plane are not running because the changes will not be picked up).
