GIT SHOWS CONNECTED TO MCP & EFIS-NOT WORKING MSFS2020
Had to build a new rig. My old one crashed. I installed the GIT it shows connected to my MCP PRO and EFIS all lights are green on the GIT but no digits lighting up and no input to the sim.
Gnacino
  • Have you enabled and configured the devices or restored from backup your old config?
  • edited August 2023
    Not sure what you mean. The devices are enabled because they show up on my pc. However I do notice that the EFIS is working on the PMDG 737, but no action on the MCPPRO. I unplugged the MCP and plugged it back in to se if I still get the lites on with the version number and I did.
    One thing though, before I would have to use GFDeFSX for default aircraft and now I can't because I no longer Have FSX. I cannot use GFconfig because there is no listing for MSFS in GFconfig.
    George
  • You need to enable the devices in GIT on each tab, select the device no and make sure it says ENABLED next to it.
    Do the rotaries work on the MCP Pro, and its just the lights and displays not working?
  • The devices are enabled in the GIT tab, I get all greens on the app. The rotaries do nothing.
    hour later,
    I was plugging and unplugging my USB devices and by accident I unplugged from my USB 3.0 to a 1.0 and guess what, It now works.
    Now I need to now how I can connect my GF config to MSFS in the store version.
    George
