Joystick blocked
Hi Steve!
I am quite sure that I am not discussing a problem of GIT64 or another product out of your portfolio but you are a VERY knowledgeable expert and maybe your knowledge about software internals can bring me a solution.
I am using
- Windows 11 (always patches to actual level)
- P3D 4.5 HF3
- GIT64
- Several GoFlight modules includingMCPpro and EFIS
- Logitech Joystick Attack3 just controlling elevator axis and aileron axis
Problem description:
When departing with my PMDG B737-900 I take off with my Joystick, stabilize the aircraft, activate the different autopilot modes on MCPpro and have a lot of fun flying the B737
BUT
when performing an ILS approach (or just a flight in autopilot mode) I switch off the autopilot by pressing CMD when passing the outer marker to finish my flight in manual mode. The MCP CMD light goes OFF but my Logitech Joystick does not react to any movements any more. So I dont get back manual control of the aircraft after an autopilot flight. The same situation I have when not only switching off CMD switch but also disengage the autopilot by moving the disengage bar switch.
Any idea how to get back manual control of the aircraft after finishing an autopilot flight ? ? ?
regards
Georg
  • Does the joystick work correctly before the autopilot is engaged?
  • Hi Steve! Yes the joystick works OK before activating the autopilot. But forget about this issue. I solved the Problem. I replaced my Logitech Attack3 joystick by my PFC Yoke and this works fine. Seems to be something related to the Logitech Joystick.
    regards
    Georg
