PMDG B737 reverse thrust in GIT64
Hi Steve!
I had las troubles bringing reversthrust to work with my GoFlight B737 throttle levers. Reading a bit through the internet I found lots of articles which covered this issue for MSFS but I am using P3Dv4. People wrote that due to bug in the software of MSFS you need not to engineer thrust reverse on the thrust reverser levers but DECREASE THROTTLE. I tried this also for my GoFlight B737 throttle levers under P3dv4 to change your default engineering to DECREASE THROTTLE and now my throttlesand reversers work fine. Maybe this could be an option to change this setting already for the basic version of GIT. On the other hand , you are right, it's not a big deal to correct.
regards
Georg
regards
Georg
THX a lot a great document. I didn't know this.
regards
Georg
