MCP Pro-LED's And Displays Are Not Working
Hi, I return to flightsimming after more than a year , trying to setup MCP Pro as before.
I got the toggle switchs, buttons and knobs working. but the LED digital display is not as photo. Can anyone help?
Updated: Problem solved by install the latest software
I’m sure I’ve seen both you and Rob Ainscough both confirm GoFlight hardware will operate just fine with USB3. I’ve ordered a new PC that only has USB3 ports. I would need a PCI card to connect to a USB2 header if the link is correct.
@salma12 , did you connect to a USB2 or USB3 port?
Ray (Cheshire, England)
I’m sure the P8 and T8 modules would be fine. It’s the 737MCP and GF166 units I’m concerned about.
