Which are the conditions for GIT to detect a USB Gaming device as Joystick?
Hello team,
I do have 2 devices which are deteced by Windows 11 as USB Gaming device but are not detected by GIT as Joystick for programming. How can I use these 2 devices in GIT for programming? What are the pre-conditions for GIT to detect a device as 'Joystick' for programming?
Thank you for your support.
Detlef
Detlef
I programmed a Throttle from Throttletek with GIT, as it was detected as Joystick.
My new Throttle from FlightsimPM is not detected by GIT as Joystick and I'm not able to program the new Throttle.
What would be the reason that the new Throttle is not detected by GIT (but detected by Windows 11 as USB Gaming device) and what can I do to make it available to GIT for programming?
Detlef
Ray (Cheshire, England)
If you activate ‚Joysticks‘ in the GIT you can also programm any Joystick button.
But the funny thing is, that it doesn‘t detect all USB gaming devices, only some. That is why I would like to understand what are the pre-conditions for GIT to detect an USB gaming device as Joystick and what I can do to activate an USB gaming device as Joystick in GIT that is not autmatically detected.
Thanks for you support.
thanks for your support. I will wait for your feedback.
Detlef
can y already give me some input? Thank you.
Detlef
any news?
Detlef
Also, in the GIT log does it list the device you need to get working?
I checked the LOG, and the required devices are enlisted as 'Supp Device'.
Detlef
17:31:58 Supp Device Found: BU0836X Interface
17:31:58 Supp Device Found: Tiller von Schiller
17:31:58 Supp Device Found: FlightSimPM DI-01
17:31:58 Supp Device Found: Landing gear
