Problem with November build for FS2020
With the latest build in the switch event drop down there are 2 entries for EVT_DOOR_CARGO_MAIN.
Using either entry instead of opening the Main Cargo Door it opens the Equipment Hatch. Any pointers to what the problem might be?
Graham
  • Its the aircraft that decides what to do when those Events fire.
  • Thanks Steve. I guess PMDG must have changed something then as it worked fine with the previous version of GIT. May have to look at going back to that and see what happens.
