GF T8 and P8 how to find the right variables the functions you want to program
Hello ,
I bought 2 x T8 and 1 x P8 second hand. I've started programming the switches on the T8 and I wanted to know how to know which variables to select in the lists ?
And when I close GIF and then open it, I no longer have the programming and I have to select the device.
thank you for your help
on Xplane for the Zibo
Roland
Roland
Roland
for my first question it's dataref and not variable
thanks
Roland
Firstly, you are not losing your programming. Its normal to have to select the device again if you wish to reconfigure it.
You can use Detective to see what Datarefs change when you doing something in the virtual cockpit. Datarefs are used for the LED's.
You will have to serach the Command list to determine what to assign to the buttons. The Commands are pretty much self explanatory.
I used another plugin that was simpler for me
Roland
