Outside view has no function
Hello Steve,
I have the problem that the Goflight instruments do not work in the exterior view.
Everything is fine in the cockpit view. Can you give me some advice?
I had the same problem before. Now after an update it is the same again.
Please help me
Greetings Peter
Please help me
Greetings Peter
Best Answers
Ok I reverted back to an older version GoFlightInterfaceToolFS2020_Setup_4_7_3_2
and now it works in cockpit and external view, so there is something in the latest version
that has changed a function -
That is bizarre. What changed? Different aircraft?deanmcenaney said:I am now having the same problem with my GF-MCP Pro, up until yesterday it would work in cockpit view or External view.
Now the autopilot will only accept commands in Cockpit view.
I have asked for help. Unfortunately, I have not yet received an answer from them.
Greetings Peter
Greetings Peter
Unfortunately I haven't gotten a proper solution yet. e.g. a software update. (release no. ?)
Thanks for your report.
Greetings Peter
I'm guessing a sim update broke some stuff in the API.
If the GIT software version didn't change it means that the tool is sending the right commands, but the sim isn't acting on them unless you're in cockpit view.
I noticed the same behavior while flying the CJ4.
Peter
