The yellow Simmconnect lights up
  • Doesn't necessarily mean there is a problem. Please post the GIT log here for me to check.
  • Where can I find the Git log
  • There is a tab called Log in GIT that you can screen dump or copy. Alternatively add /log to the target entry of GIT's icon on your desktop and a log file will be made in Documents\GoFlight Interface Tool.
  • Hello Steve
    I'll send you the log file again so that you can locate the error with the yellow connect lamp.
    Greetings Peter
  • Hello Steve
    Did you forget me?
    Greetings Peter
  • Sorry for the late reply. It looks like you are missing the GIT WASM module in your community folder. You can download it from your account and copy the contents including the main folder into your community folder.
  • Hello Steve
    Which download do I need to download for the WASM module so that I have the correct version. This also fixes the error that there is no function in the external view.
    Greetings Peter
  • Its called GIT FS2020 Module (If Needed).zip
  • When did the problem start/what changed on your system?
