Application Halted - Unable to save settings:Object reference not set to an instance of an object
Object reference not set to an instance of an object Application Halted and crashes every time I load the application. Im running Xplane 12, Worked Yesterday but today its giving me these errors. I have tried deleting everything in my appdata local setting as suggested in previous post but it dosnt do anything to fix the issue.
  • Can you screen dump the error message please.
  • edited May 2024
    hello, after update of xplane 12 I have exactly the same problem, I tried everything and cannot launch the software :'(
  • Maybe the software is incompatible somehow with Xplane 12 recent update? Maybe the software needs to be updated
  • The problem is with XPlanes DataRefs.txt file. There are 4 lines that are incorrect:
    [0] = autobrake 1 = 0.125g
    [1] = autobrake 2 = 0.155g
    [2] = autobrake 3 = 0.225g
    [3] = autobrake 3 = 0.4g
    A quick workaround is to delete the above entries from the DataRefs.txt file located in your XPlane resources\plugins folder.
    I will put out a release over the weekend that can ignore these incorrect entries, but for those wanting a quick fix, do the above.
