[SDK] EnableDataBroadcast=1
I know PMDG have added the "EnableDataBroadcast=1" into all their Boeings software, meaning we don't have to add it into the Option.ini file anymore (it no longer exists) but it's not working for me. Although my MCP does control the Boeing 777 in the cockpit, my Go-Flight MCP remains just showing zero's i.e. it's getting no feedback with the DataBroadcast. Can it be fixed? or is it a problem with PMDG software?
From the PMDG 777 SDK manual (GIT should do this for you, but double check it):
To enable the data communication output, you will need to open the file
777_Options.ini that is located in the 777 persistent storage folder.
For Microsoft Store distribution, this folder is located at
%LOCALAPPDATA%\Packages\Microsoft.FlightSimulator_8wekyb3d8bbwe\Lo
calState\packages\pmdg-aircraft-77w\work\.
For Steam distribution, this folder is located at
%APPDATA%\Microsoft Flight Simulator\Packages\pmdg-aircraft77w\work\.
Once this folder is open, add the following lines as required to the bottom of
the file:
[SDK]
EnableDataBroadcast=1 is included in all new downloads of all airplanes from PMDG it is now within the software of each aircraft if this is incorrect why can't I find Options.ini?
EnableDataBroadcast=1 into. see attached pic
\Lockheed Martin\Prepar3D v4\PMDG\PMDG 777X\.
