Simconnect
Hello
The problem is that the yellow Simconnect light is on. I downloaded the latest version from the website and installed it. Without success. I also had no success with older versions. I'm desperate.
The problem that no animation can be seen in the external view with the latest version (landing gear, flaps, etc.) has not yet been solved.
It would also be nice if the version could be recognized in the software.
It's a shame. Flying is no fun like this. I ask you to solve the problems.
Regards, Peter
  • I'm sending you the log file in the attachment.
    Regards, Peter
  • Looks like you are missing the GIT WASM module in your community folder. You can download and install it manually from your account downloads.
  • Hello Steve
    Thanks for your answer. I can't find the "Windows8Fixer.cmd". Can you tell me the path where this file is located?
    Thanks for your help
    Regards Peter
  • Its part of the original GoFlight drivers. If you don't have them installed, its available in the website downloads area. Path is normally C:\Program Files (x86)\GoFlight
  • hello Steve
    thank you very much for your help. It's working again.
    The only thing is that the movements (flaps, gear etc.) are not yet visible in the external view.
    it would be nice if you could fix this error too.
    kind regards
    Peter
  • I think the MS dev team keep stand boxing the keyboard inputs, because this was working previously. I'll take another look.
