GF EFIS and PMDG 777 MSFS2020
The GIT works perfectly with the PMDG 73X. However, in the 777 the Altimeter and DH knobs do not work at all (everything else functions properly). I have the latest GIT version installed. Any comments and help would be appreciated--Thanks
  • Thats odd as its the same code from the 777 for Prepar3D. I'll check my end and come back to you.
  • sorry to bring this item back again - PMDG B77W EFIS Mins and Baro rotaries doesn't work, neither at EFIS nor at assigned GF-RP48 rotary. How can I assing the 1/-1 (>L:CABaroKnob and L:CAMinsKnob) to a bespoke event since detective is not working in PMDG B77W? Best regards
  • I do have the same question and it would be great to have that topic solved.
    Everything else is working perfectly with the PMDG777.
  • I'm doing update work on GIT tomorrow for FS2024, so will look at this as well. Detective does not work with PMDG because everything can be done via their SDK which is built into GIT.
  • edited December 2024
    Hello, trying to resurect this thread as I do not want to open a new one with similar issues,
    I did the updated software about a week ago and since then the F/O EFIS would not switch, If I select COPILOT it still controls the ND on the capt side. DISABLE does disable it and selectin CAPT still controls the capt side ND,
    I have done multiple restarts and still not control the F/O side.
    This is being used for the PMDG 737 - thought i clarify this here
    Please help
  • Nothing has changed in that area so I'm very surprised by this. Try renaming Documents\GoFlight Interface Tool so GIT starts unconfigured and then try setting the EFIS again.
  • Steve, you are a genuis. This worked for me. Much appreciated.
  • I seem to be having the same issue with the 777s Altimeter and DH knobs. All the other knobs on the EFIS work. I’m up-to-date. tried deleting the config file.
    any help would be greatly appreciated.
