GFIT MSFS2020 GoFlight Status red
Hello, Steve, GFIT was working well until a MSFS2020 CTD and after a restart I can no longer use the GFIT software, using MSFS2020, WIN10 all updated and latest GFIT version 4.81, tried with several AC's - no help, the GoFlight Status Indication is steady red.
After starting MSFS and GFIT the Goflight Status remains red steady, Simconnect green steady and AC flashing red. I have checked the GFDev64.dll - it is located in the same directory as the Goflight Interface Tool MSFS.exe as well as FlightSim IOLua.exe and other files. Then I have done a complete re-install, checked the community folder for the WASM module, it is there and the PMDG broadcast entry in the option.ini is also set to 1. All GFIT tabs greyed out except Settings/Log and Status, no modules indicated above the status indicator. Several new-installations did not solve the problem unfortunately, seems the GFDev64.dll will not be recognized... but I'm not sure, Checked also with the previous GFIT version, same bahaviour as with 4.8.1. The GFIT can only closed via task manager / stop (kill) task. See the log.file, after starting LUA nothing will happen, LUA windows itself can be opened, and of course several PC restarts and MSFS resets completed, no effect at all.
At the moment I have no more ideas how to solve the problem, please advise how to proceed.
Thank you and best regards Ralf
01:03:57 GoFlight Connection Starting.....
01:03:57 SimConnect Connection Starting.....
01:03:57 SimConnect Message Processing Started
01:03:58 SimConnect Connection Started
01:03:58 Aircraft Connection Starting.....
01:03:58 PMDG SDK option is OK in FS2020
01:03:58 SimConnect: Event Received: Aircraft Type Changed
01:03:58 SimConnect: Event Received: SIM, 1
01:03:58 SimConnect: Event Received: PAUSE, 0
01:03:58 SimConnect: Event Received: VIEW, 2
01:03:58 SimConnect Message Processing Finished
01:03:58 SimConnect Connection Starting.....
01:03:59 SimConnect Message Processing Started
01:04:00 SimConnect Connection Started
01:04:00 Aircraft Connection Starting.....
01:04:00 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
01:04:00 SimConnect: Event Received: SIM, 1
01:04:00 SimConnect: Event Received: PAUSE, 0
01:04:00 SimConnect: Event Received: VIEW, 2
01:04:01 WinSock: Connected To localhost On Port 27016!
01:04:01 LUA Processor: Started!
but thenafter nothing happens, only the task-kill could end the GFIT application....
