Installation Problem with GoFlight Interface Tool X-Plane Commercial
Hello, I have problems with installing the GoFlight Interface Tool X-Plane Commercial.
Shortly before the installation is complete, the following error message appears:
Unable to execute file: C:\Program Files (x86)\GoFlight Interface Tool X-Plane\vcredit_x86_VS2019.exe
CreateProcess failed: code 2. The system cannot find the specified file.
After i have finish the installation despite the error message and try to open the GoFlight Interface Tool X-Plane, nothing appears, no error message, nothing. In the task manager the Goflight Interface not appear.
I've tried the following:
1. Downloaded VC_redist.x86.exe, disabled my antivirus software, and installed the file as administrator. Restarted my PC.
2. Downloaded the GoFlight Interface Tool X-Plane Commercial again, unzipped with 7zip, disabled my virus scanner, and installed it as administrator.
Same problem as described above.
I'm using the GoFlight Interface Tool P3Dv4 64-bit too, which work flawlessly for years.
System: Windows 11, AMD Ryzen 9, GeForce 5080
Can anyone help me? Thank you very much.
  • Hello, no one has an idea? Can someone tell me whether all the files are contained in the installation folder (see attachment). Isn't the GFDev64.dll file missing?
  • Sorry for the late reply, I've been away. I have just checked and it looks like the installer has some old code in it. I will rebuild it and let you know when its been uploaded.
  • New installer has been built and tested, so re-download GIT from your account and it should work OK now.
