Installation Problem with GoFlight Interface Tool X-Plane Commercial
Hello, I have problems with installing the GoFlight Interface Tool X-Plane Commercial.
Shortly before the installation is complete, the following error message appears:
Unable to execute file: C:\Program Files (x86)\GoFlight Interface Tool X-Plane\vcredit_x86_VS2019.exe
CreateProcess failed: code 2. The system cannot find the specified file.
After i have finish the installation despite the error message and try to open the GoFlight Interface Tool X-Plane, nothing appears, no error message, nothing. In the task manager the Goflight Interface not appear.
I've tried the following:
1. Downloaded VC_redist.x86.exe, disabled my antivirus software, and installed the file as administrator. Restarted my PC.
2. Downloaded the GoFlight Interface Tool X-Plane Commercial again, unzipped with 7zip, disabled my virus scanner, and installed it as administrator.
Same problem as described above.
I'm using the GoFlight Interface Tool P3Dv4 64-bit too, which work flawlessly for years.
System: Windows 11, AMD Ryzen 9, GeForce 5080
Can anyone help me? Thank you very much.
The installation now worked without any error messages. However, when entering the key, the message "Invalid key" appeared. I've sent the problem via the contact function.
