Can't install 2.1.13.0 interface
Hi
I've downloaded the latest version of the P3D Goflight Interface Tool (2.1.13.0) but when i try to install it i get an error message
source file not found.
 .............Goflight Interface Tool P3D 2-1-13-0\install\disk1.cab
Any ideas?
Elfyn
  • Hi Elfyn,
    Sounds like the download is corrupt. I would clear your browser cache and redownload.
  • I've tried clearing the cache. I've used google chrome instead of firefox, with no luck. I have tried temp disabling antivirus and firewall, the web download and dropbox one for both P3D and FSX:SE.
    Everything results in the same message.
  • I've emailed the files to you.
  • Thanks Steve. I've tried the downloads with the same result. I'm guessing its something with my rig but cant work out what.
  • I have just installed them fine here. Does the appdata\temp directory have sufficient storage space? Have you tried running it as administrator?
  • Also, try extracting the setup.exe file out of the zip folder before running it!
  • Had already tried from the zip and extracted. The drive im using has over 30gb free space so storage space shouldn't be an issue. Tried running in admin but the installer flashes up for permission even when i dont before it starts.
    I have found that it appears to be installing the setup.exe into Roaming\PollyPot Software\GoFlight Interface Tool P3D 2.1.13.0\install\
    I've tried running this with the same outcome.
    The old PMDGinterface client installs and works fine.
  • edited June 2015
    Its a weird one! I've copied all the files for all the versions into a rar file for you on Dropbox. Simply copy the contents into your \program files (x86)\Goflight directory and make shortcuts on you desktop for the main files.
    The link is:
    https://www.dropbox.com/s/pgf824xqk4jqfpx/GIT.rar?dl=0
  • Thanks for all your help Steve. All seems to work. I can run the program anyway. I will give it a proper test run when I get home from work tomorrow.
  • Ok so I couldn't wait. Everything works fine apart from 1 thing. I only have the TQ6-ADV throttles and my one issue is when I try to use the TOGA buttons with the PMDG 777. I hear the button press then P3D CTD's on me.
    Its getting late and I start work 4:30 in morning so must get some shut eye in. Will check forum for this issue tomorrow. If you could steer us in the right direction Steve I would be very grateful.
    Again thanks for all your help
    Elfyn
  • Hi Elfyn,
    It worked OK for me. Have you tested the 777 TOGO without using the TQ6?
    What version of the 777 are you using?
  • I had that was fine. I think it was either a bug in my P3D or PMDG somewhere I've done a clean install of P3D and the T7 and all seems fine now.
    Elfyn
