Detective button does not work. Airbus 320 aerosoft
Hello. I am trying to use my MCP and EFIS in the Aerosoft Airbus 320. I follow the following instructions
3e) Using Notepad, open the dll.xml file and locate the following line: <Launch.ManualLoad> False </Launch.ManualLoad>
Immediately Under This line, copy and paste the following, changing the directory included Within <Path> </ Path> to the directory Where You esta software installed:
<Launch.Addon>
<Name> GoFlight Interface Module </ Name>
<Disabled> False </ Disabled>
<Path> C: \ Program Files (x86) \ GoFlight \ GoFlight Interface Module.dll </ Path>
</Launch.Addon>
Following these instructions, the simulator opens but closes immediately. Any solution?
  • Hi pablomas5,
    See the FAQ section titled "The Interface Software Crashes After PMDG SDK License Acceptance" and "FSX/P3D/FSX SE Crashes on start up indicating an error with the Goflight Interface Module"
  • Thank you. I tried the 2 options, but did not work...
  • Is there any error message appearing when you restart the flight sim after the first crash?
  • What is detective and Where do i find it cause i am interested in making my MCP PRO working on AS320
  • Its a button on the Status tab.
