Mapping Blacksquare Caravan Turbine FS2024 turbine ignition event to GoFlight SECM
I try to map the turbine ignition on event from Blacksquare C208 Caravan to switch position 2 of the GoFlight SECM Engine Selector.
When I move the switch in the cockpit GIT sees the event TURBINE_IGNITION_SWITCH_SET1 with Lvar 0002. When I generate my event for the SECM Ifirst write a 1 to self defined Bespoke varible, which I use later to identify the switch position but the second line is TURBINE_IGNITION_SWITCH_SET1 with Lvar 0002, but nothing happens in the cockpit. Do you have any experience with the Blacksquare events or Lvars? Detective also reads TURBINE_IGNITION_SWITCH_SET1 with Lvar 0002 when I test my event.
regards
Georg
  • edited August 11
    Hi Georg,
    Are there any Commands/additional variables showing up in Detective before and after you see TURBINE_IGNITION_SWITCH_SET1 appear? Sometimes you need to do a combination of things together to get the aircraft to respond.
  • Hi Steve
    NOT for setting the ignition switch to ON. When switching back to OFF DETECTIVE shows the Ignition Switch event and a Ignition Switch toggle event.
    I rebuilt both situations shown by DETECTIVE, but nothing happening.
    regards
    Georg
  • edited August 12
    Hi Georg,
    So you have tried the Ignition Switch command and then setting the TURBINE_IGNITION_SWITCH_SET1 lvar both together in a single Bespoke Event?
