GF-LGT
Gear selection, I have On = gear down, with gear_total_pct_extended, all 3 gear selected with a 0.
Gear retract and extends fine, the 3 green lights come up when extended and locked.
Is there any way to have the lights in transit show as they do with the GF module ?
PMDG set up without having to select flaps in GF module.
Is it possible to have the flap selection active in the GTI interface or have the flap switch incorporated with the PMDG interface ??
Nice to be able to swap from one plane to another without having to preselect a go-flight module setup. Great solution Steve.
Trevor
  • edited March 2013
    Hi Trevor,
    "Is there any way to have the lights in transit show as they do with the GF module ?" I'll need to write the code for that - I'll add it to the Development Plan.
    "PMDG set up without having to select flaps in GF module." When the NGX is migrated to the Generic Platform, you will be able to do this.
