Director not working
Hey Guys i tried using the MCP for Airbus X extended and when I import the XML files i get an error saying:
Import has failed: Could not find file C/Program Files (x86) ............" what sould I do ??
thanks
Can you give the full error message or attach a print screen.
i wanted to attach the print screen but I don't see the option
There should be "Attach a file" under the comment box.
Isaac
Just email it to me at info@pollypotsoftware.org.uk.
Confirmed bug. See Current Bug List and included workaround.
I don't keep old versions available. You did attempt to import the original downloaded xml file and NOT the Vars file I sent you?
Ok. I'll write a bug fix and get a new version out tomorrow.
New version is now available that fixes this problem.
