Director not working
Hey Guys i tried using the MCP for Airbus X extended and when I import the XML files i get an error saying:
Import has failed: Could not find file C/Program Files (x86) ............" what sould I do ??
thanks
  • Can you give the full error message or attach a print screen.
  • i wanted to attach the print screen but I don't see the option
  • There should be "Attach a file" under the comment box.
  • I am on the iphone now but can you explain to me where should i put the files cause i've already got them and I already know how to do the procedure so I just want to be sure that my files are in the right directory
    Isaac
  • Just email it to me at info@pollypotsoftware.org.uk.
  • Confirmed bug. See Current Bug List and included workaround.
  • still it is not working with that fix sent you a mail disreguard it, can we try with an older Interface version, have you got one for me or where could i find one
  • I don't keep old versions available. You did attempt to import the original downloaded xml file and NOT the Vars file I sent you?
  • yes sir I did when i dowloaded it
  • Ok. I'll write a bug fix and get a new version out tomorrow.
  • New version is now available that fixes this problem.
