rotary knobs
Can someone give an example of how to program a rotary knob? I can get the on off switches to work after I use detective to determine the event name but have no clue how to program an event that required a rotary knob.
Jim
  • Hi Jim,
    What aircraft are you using? I'm asking because the NGX and 77X handle it differently.
  • I'm trying to program for the q400. I know there are challenges with that aircraft until the pro version comes out.
    Jim
  • You need to use CLOCKWISE/ANTICLOCKWISE Input Events with a different event for each and the Input Action ROTATE.
    E.g. for an autopilot's VOR course:
    CLOCKWISE, VOR1_OBI_INC, ROTATE
    ANTOCLOCKWISE, VOR1_OBI_DEC, ROTATE
  • I'm afraid that doesn't have any effect. I have the Mcpro with default fs options working so The course knobs are working. The one I'm trying to program is the barometric pressure dial. Using detective I see the event is MAIN_INDEX1_QNH_KNOB_ANGLE. lvar Data : 39
    Obviously lvar increasing and decreasing is the event I'm looking for but I can't seem to get this to work. Any ideas? I'm trying to program the rotators knob on the rp 48
    Jim
  • That looks like the angle of the knob to do with displaying its image in the VC. Have you tried the simconnect barometric events?
  • Yes, there doesn't seem to be any effect using the barometric event.
    Jim
  • I have found the following on a forum which should sort everything out for you (note the XML variables show up as Lvars):
    Abstract
    This document is a specification for the FSX XML vars based External Interface included in the MJC Platform
    Applicability
    Applies to every edition of the MJC8Q400 version 1.008
    Description
    The XML based access to MJC8Q400 systems can be used to read and write most of the numerical variables within the MJC8Q400
    Access is performed in a request/response sequences via 4 dedicated XML variables:
    MJC_VAR_READ_CODE
    MJC_VAR_READ_VALUE
    MJC_VAR_WRITE_CODE
    MJC_VAR_WRITE_VALUE
    Interface contains 2 special return codes, which are returned in the MJC_VAR_READ_CODE/MJC_VAR_WRITE_CODE:
    9991999 // Acknowledge success
    9992999 // Acknowledge variable not found
    READING THE VARIABLES
    To read a variable from MJC, a requestor would perform the following steps:
    Design time
    1. Identify the variable name in the varlist.xlsx located under \SimObjects\Airplanes\mjc8q400\doc\scripts
    2. Derive the 32 bit var name hash using the IntVarCRCGen.exe utility
    Run time
    3. Write the var name hash into MJC_VAR_READ_CODE
    4. Wait for MJC_VAR_READ_CODE to indicate one of the Acknowledge codes (success, or var not found)
    5. If Ack is success, the variable value is in the MJC_VAR_READ_VALUE
    WRITING THE VARIABLES
    To write a variable to MJC, the following steps are performed
    Design time
    Run time
    3. Write the desired variable value into MJC_VAR_WRITE_VALUE
    4. Write the var name hash into MJC_VAR_WRITE_CODE
    5. Wait for MJC_VAR_WRITE_CODE to indicate one of the Acknowledge codes (success, or var not found)
    6. If Ack is success, the variable was written
    Considerations:
    + Only the numerical variables can be accessed by the XML interface
    + A Read and a Write operation can be executed concurrently
    + The response time of the interface equals to a single FSX visual frame. Due to this fact, the interface might be blocked during aircraft repositions or while the blocking FSX dialogs, such as select flight, or weather setting are shown
    Copyright (c) 2013 Majestic Software
    Forum link here: http://www.molitor-home.de/fs/forum/viewtopic.php?t=1729&p=7123
  • Wow sounds promising, I wish I was smart enough to figure out how to do this.
    Can someone post an example of using this..
    Jim
  • Brilliant! It works great.. thanks for that Steve.
    Jim
  • This is all really great stuff. Do you think it would be possible to get an updated MCPRO profile for the Q400?
    Also, I'm having difficultly with the "EFISdata_->EFCP_controls1.range_selector" What value needs to into the "MJC_VAR_WRITE_VALUE" ? If I use 1 the knob snaps back to the 20mile range but I can't get it to move from there. I can see from detective that the knob moves in increments of 5 I think.
    Jim
  • Hi Jim,
    If you have Goflight hardware selectors, you will need a Bespoke Event for each position on the selector. Each of the Bespoke Events will send a different MJC_VAR_WRITE_VALUE (I assume starting from 0, then 1, then 2, then 3 etc.). You can then assign the relevant  Bespoke Event to a Goflight Selector position.
    If you are trying to use the Bespoke Events on a rotary, you would need 2 Bespoke Events (clockwise and anticlockwise). They would need to read the current value (i.e. the current position) as described in the how to lights guide mentioned in a previous post, then add (Set +) or subtract (Set -) 1 from the bespoke variable assigned the position data and then use Set = to set the MJC_VAR_WRITE_VALUE to the updated bespoke variable. Also include an If check to limit the max and minimum values of the bespoke variable so you cannot go over the allowed position values.
  • Hi again,
    I'm trying to program the IAS button on the autopilot to work with the speed button on the MCpro.
    I'm using
    MJC_VAR_WRITE_VALUE = 1
    MJC_VAR_WRITE_CODE=42203
    but am having no luck, it should be the AP_indicated_airspeed_mode  button.
    Can anyone help? Steve?
    Jim
  • Hi Jim,
    I get 33470 for the write code. Remember to remove any spaces in the variable name.
  • Steve does it not go in like this?
    AFCS_->FGM[1].ias_to_maintain
    =42203
    perhaps i'm using the wrong line item
    Jim
  • edited July 2015
    Its AFCS_->inputs.mode_button.
    You use a value of 0 to 13 as follows
    NONE 0, IAS 1,
    VS 2, VNAV 3, ALT 4, ALTSEL 5, HDG
    6, NAV 7, APPR 8, BC  9, STBY 10, AP  11, YD
    12, HSISEL 13
  • Thanks Steve, I missed that one, works great now.
    I'm having an issue assigning a few engine commands, perhaps they are not programmable.
    I'm looking to assign the following to push buttons on my GF-P8
    MCL (Maximum Climb power)
    MCR (Maximun Criuse power)
    MTOP (Maximum take off power)
    I can't find them on the XML file.
    Can anyone help with this?
    Jim
  • Hi Jim,
    Use a write code of 198197 and the following write values:
    1 - MTOP, 3 RDC TOP RESET, 4 - RDC TOP DEC, 5 - MCL, 6 - MCR, 7 - RDC NP
  • Wow that was quick, thank you so much, I forgot to add Autofeather as well.
    Jim
  • Engine 1: 68825, 0 - OFF, 1 - ON
    Engine 2: 119566, 0 - OFF, 1 - ON
  • Thanks Steve but the MJC model shows only one button for Autofeather?
    Jim
  • My mistake, its just 68825 with 1 or 0.
  • Thank you Steve
    Jim
  • Awaking this old thread, has anyone done some work on programming knobs in X-Plane ?  I am using GIT with GA type planes and having trouble attacking the problem of getting RP-48 knobs to be used for adjusting altimeter, moving the bug around, and so on.  I can't seem to find any examples around...
    Terry
  • Hi Terry,
    Its very straight forward. Open up the file <xplane directory>\Resources\plugins\Commands.txt in a decent editor (I recommend Notepad++). Search for what you want to change e.g. heading or alt. You will then locate suitable commands that can be sent to XPlane. All you need to do is assign these commands to the CLOCKWISE and ANTICLOCKWISE inputs via the dropdown list boxes for the rotary concerned. Use the Input Action of ROTATE.
    E.g for autopilot altitude:
    CLOCKWISE: sim/autopilot/altitude_up
    ANTICLOCKWISE: sim/autopilot/altitude_down
    Input Action: ROTATE.
    Remember to enable the device if you haven't already.
  • thanks ! I'll give it a try...
