rotary knobs
Can someone give an example of how to program a rotary knob? I can get the on off switches to work after I use detective to determine the event name but have no clue how to program an event that required a rotary knob.
Jim
Jim
Hi Jim,
What aircraft are you using? I'm asking because the NGX and 77X handle it differently.
Jim
You need to use CLOCKWISE/ANTICLOCKWISE Input Events with a different event for each and the Input Action ROTATE.
E.g. for an autopilot's VOR course:
CLOCKWISE, VOR1_OBI_INC, ROTATE
ANTOCLOCKWISE, VOR1_OBI_DEC, ROTATE
Obviously lvar increasing and decreasing is the event I'm looking for but I can't seem to get this to work. Any ideas? I'm trying to program the rotators knob on the rp 48
Jim
That looks like the angle of the knob to do with displaying its image in the VC. Have you tried the simconnect barometric events?
Jim
I have found the following on a forum which should sort everything out for you (note the XML variables show up as Lvars):
Abstract
This document is a specification for the FSX XML vars based External Interface included in the MJC Platform
Applicability
Applies to every edition of the MJC8Q400 version 1.008
Description
The XML based access to MJC8Q400 systems can be used to read and write most of the numerical variables within the MJC8Q400
Access is performed in a request/response sequences via 4 dedicated XML variables:
MJC_VAR_READ_CODE
MJC_VAR_READ_VALUE
MJC_VAR_WRITE_CODE
MJC_VAR_WRITE_VALUE
Interface contains 2 special return codes, which are returned in the MJC_VAR_READ_CODE/MJC_VAR_WRITE_CODE:
9991999 // Acknowledge success
9992999 // Acknowledge variable not found
READING THE VARIABLES
To read a variable from MJC, a requestor would perform the following steps:
Design time
1. Identify the variable name in the varlist.xlsx located under \SimObjects\Airplanes\mjc8q400\doc\scripts
2. Derive the 32 bit var name hash using the IntVarCRCGen.exe utility
Run time
3. Write the var name hash into MJC_VAR_READ_CODE
4. Wait for MJC_VAR_READ_CODE to indicate one of the Acknowledge codes (success, or var not found)
5. If Ack is success, the variable value is in the MJC_VAR_READ_VALUE
WRITING THE VARIABLES
To write a variable to MJC, the following steps are performed
Design time
Run time
3. Write the desired variable value into MJC_VAR_WRITE_VALUE
4. Write the var name hash into MJC_VAR_WRITE_CODE
5. Wait for MJC_VAR_WRITE_CODE to indicate one of the Acknowledge codes (success, or var not found)
6. If Ack is success, the variable was written
Considerations:
+ Only the numerical variables can be accessed by the XML interface
+ A Read and a Write operation can be executed concurrently
+ The response time of the interface equals to a single FSX visual frame. Due to this fact, the interface might be blocked during aircraft repositions or while the blocking FSX dialogs, such as select flight, or weather setting are shown
Copyright (c) 2013 Majestic Software
Forum link here: http://www.molitor-home.de/fs/forum/viewtopic.php?t=1729&p=7123
Can someone post an example of using this..
Jim
Hi Jim,
I've just written a little guide for you and others. Its here: http://www.pollypotsoftware.org.uk/support/forum.html#/discussion/230/how-to-guide-build-bespoke-events-for-the-majestic-dash-q400
Jim
Hi Jim,
Just added a guide for the lights: http://www.pollypotsoftware.org.uk/support/forum.html#/discussion/231/how-to-guide-settings-lights-for-the-majestic-dash-q400
Also, I'm having difficultly with the "EFISdata_->EFCP_controls1.range_selector" What value needs to into the "MJC_VAR_WRITE_VALUE" ? If I use 1 the knob snaps back to the 20mile range but I can't get it to move from there. I can see from detective that the knob moves in increments of 5 I think.
Jim
Hi Jim,
If you have Goflight hardware selectors, you will need a Bespoke Event for each position on the selector. Each of the Bespoke Events will send a different MJC_VAR_WRITE_VALUE (I assume starting from 0, then 1, then 2, then 3 etc.). You can then assign the relevant Bespoke Event to a Goflight Selector position.
If you are trying to use the Bespoke Events on a rotary, you would need 2 Bespoke Events (clockwise and anticlockwise). They would need to read the current value (i.e. the current position) as described in the how to lights guide mentioned in a previous post, then add (Set +) or subtract (Set -) 1 from the bespoke variable assigned the position data and then use Set = to set the MJC_VAR_WRITE_VALUE to the updated bespoke variable. Also include an If check to limit the max and minimum values of the bespoke variable so you cannot go over the allowed position values.
I'm trying to program the IAS button on the autopilot to work with the speed button on the MCpro.
I'm using
MJC_VAR_WRITE_VALUE = 1
MJC_VAR_WRITE_CODE=42203
but am having no luck, it should be the AP_indicated_airspeed_mode button.
Can anyone help? Steve?
Jim
Hi Jim,
I get 33470 for the write code. Remember to remove any spaces in the variable name.
AFCS_->FGM[1].ias_to_maintain
=42203
perhaps i'm using the wrong line item
Jim
Its AFCS_->inputs.mode_button.
You use a value of 0 to 13 as follows
NONE 0, IAS 1,
VS 2, VNAV 3, ALT 4, ALTSEL 5, HDG
6, NAV 7, APPR 8, BC 9, STBY 10, AP 11, YD
12, HSISEL 13
I'm having an issue assigning a few engine commands, perhaps they are not programmable.
I'm looking to assign the following to push buttons on my GF-P8
MCL (Maximum Climb power)
MCR (Maximun Criuse power)
MTOP (Maximum take off power)
I can't find them on the XML file.
Can anyone help with this?
Jim
Hi Jim,
Use a write code of 198197 and the following write values:
1 - MTOP, 3 RDC TOP RESET, 4 - RDC TOP DEC, 5 - MCL, 6 - MCR, 7 - RDC NP
Jim
Engine 1: 68825, 0 - OFF, 1 - ON
Engine 2: 119566, 0 - OFF, 1 - ON
Jim
My mistake, its just 68825 with 1 or 0.
Jim
Hi Terry,
Its very straight forward. Open up the file <xplane directory>\Resources\plugins\Commands.txt in a decent editor (I recommend Notepad++). Search for what you want to change e.g. heading or alt. You will then locate suitable commands that can be sent to XPlane. All you need to do is assign these commands to the CLOCKWISE and ANTICLOCKWISE inputs via the dropdown list boxes for the rotary concerned. Use the Input Action of ROTATE.
E.g for autopilot altitude:
CLOCKWISE: sim/autopilot/altitude_up
ANTICLOCKWISE: sim/autopilot/altitude_down
Input Action: ROTATE.
Remember to enable the device if you haven't already.
