GFIT Warning message
I recently installed and subsequently uninstalled FSX:SE. Now when running FSX (Boxed) and launching GFIT , I get a Warning box stating that FSX:SE ini file not found, PMDG operations file cannot be checked/updated. Followed by another warning for Prepar3d (which I have neer installed) Prepar3D registry AppPath entry not found, PMDG options cannot be checked/updated. In Settings, Enable Prepar3D is unchecked
7:01:39 Simconnect Version: 10.0.61259.0
After hitting OK, it seems that my GF hardware is not properly working.
Here is a log snippit:
07:01:39 Synchronising Switches & Selectors .....
07:01:39 Synchronising Switches & Selectors: Waiting for Simconnect .....
07:01:47 PMDG SDK option is OK in FSX
07:01:47 FSX SE ini file not found
07:02:45 Prepar3D registry AppPath entry not found
07:04:05 SimConnect: Event Received: Aircraft Type Changed
07:04:05 GoFlight Connection Starting.....
07:04:05 SimConnect Message Processing Finished
07:04:06 SimConnect Connection Starting.....
07:04:07 SimConnect Message Processing Started
07:04:07 SimConnect Connection Started
07:04:07 Aircraft Connection Starting.....
07:04:07 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
07:04:07 SimConnect: Event Received: SIM, 0
07:04:07 SimConnect: Event Received: PAUSE, 0
07:04:20 GoFlight Connection Started
I've tried an complete uninstall of GFIT but no joy. Short of a re-install of FSX:SE, how can I get rid of this message?
Kevin
Hi Kevin,
Untick "Enable for FSX" (its checks FSX SE also) and "Enable for Prepar3D" on the Settings tab. These tick boxes simply check for PMDG aircraft entries in the relevant simulators.
