Cannot save settings
I have recently upgraded to goflight interface fsx and now I can't seem to save any Setting anymore yet before I uninstalled the pmdg version everything was working fine.
I have also uninstalled/reinstalled serveral times but still cannot save any configs is there something I'm missing here ?
Craig
  • Hi Craig,
    The configs are saved automatically. You can check by looking at My Documents\GoFlight Interface Tool\PMDG.XML and Settings.XML.
    Thanks of the info sorry I'm a little late in getting back to you I work away sometimes and when I'm home have tried to resolve this to no avail.
    I'm pulling my hair out still can't seem to get this working since the upgrade, switches appear to be ok can't get leds working unless in identify mode?
    I have checked the log and this is what i'm getting it there a way to resolve this, I've also attached my config if this helps as well to see where I'm going wrong.
    Craig
    20:16:33 GoFlight Connection Starting.....
    20:16:33 SimConnect Connection Starting.....
    20:16:34 GoFlight Connection Started
    20:17:03 SimConnect Message Processing Started
    20:17:03 SimConnect Connection Started
    20:17:03 Aircraft Connection Starting.....
    20:17:04 Aircraft Connection Started
    20:17:04 Simconnect Version: 10.0.61259.0
    20:17:04 Synchronising Switches & Selectors .....
    20:17:04 Synchronising Switches & Selectors: Waiting for SimConnect .....
    20:17:06 SimConnect: Event Received: Start
    20:17:06 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    20:17:06 SimConnect: Event Received: SIM, 0
    20:17:06 SimConnect: Event Received: PAUSE, 0
    20:17:06 SimConnect: Exception Received:  OUT_OF_BOUNDS
    20:17:14 PMDG SDK option is OK in FSX
    20:17:14 SimConnect: Event Received: Aircraft Type Changed
    20:17:14 SimConnect Message Processing Finished
    20:17:14 GoFlight Connection Starting.....
    20:17:15 SimConnect Connection Starting.....
    20:17:16 GoFlight Connection Started
    20:17:16 SimConnect Message Processing Started
    20:17:16 SimConnect Connection Started
    20:17:16 Aircraft Connection Starting.....
    20:17:17 SimConnect: Event Received: Start
    20:17:17 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
    20:17:17 SimConnect: Event Received: SIM, 0
    20:17:17 SimConnect: Event Received: PAUSE, 0
    20:17:17 Aircraft Connection Started
    20:17:17 Simconnect Version: 10.0.61259.0
    20:17:18 SimConnect: Exception Received:  EVENT_ID_DUPLICATE
    20:17:18 SimConnect: Exception Received:  UNRECOGNIZED_ID
    20:17:38 SimConnect: Event Received: SIMSTART, 0
    20:17:38 SimConnect: Event Received: SIM, 1
    20:18:09 Synchronising Switches & Selectors Complete
  • Cannot seem to attach my XML file I've tried to zip them but still wont upload.
    Worst case is it possible to just delete these files and start again as I don't have anything major setup yet only just started setting up my mip panel?
    Craig
  • Hi Craig,
    Yes delete all the files or rename the My Documents\Goflight Interface Tool directory.
