MCP-Pro Unrecognized_Id Error
i just installed my MCP-Pro and ver 2.2.5.0 of the GF Config program. I then installed ver 2.1.14.2 of the Inteface Tool. Both programs are instaled on my G: drive. I start the interface tool and then start FSX. The Status shows 3 green lights. I then select and load the PMDG 737 and the SimConnect light goes yellow and the Aircraft light goes flashing green. Most things seem to work with the exception of the N1 and APP butttons. There is an "Unrecognized_id" error in my log (see below). I also notice that some of my keyboard commands don't work (e.g., Control + "." no longer sets the parking brake. Also, the Detective button is not active. Any help would be appreciated.
11:21:04 GoFlight Connection Starting.....
11:21:04 SimConnect Connection Starting.....
11:21:05 GoFlight Connection Started
11:28:22 SimConnect Message Processing Started
11:28:22 SimConnect Connection Started
11:28:22 Aircraft Connection Starting.....
11:28:23 Aircraft Connection Started
11:28:23 Simconnect Version: 10.0.61259.0
11:28:23 Synchronising Switches & Selectors .....
11:28:23 Synchronising Switches & Selectors: Waiting for Simconnect .....
11:28:33 SimConnect: Event Received: Start
11:28:33 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
11:28:33 SimConnect: Event Received: SIM, 0
11:28:33 SimConnect: Event Received: PAUSE, 0
11:29:00 PMDG SDK option is OK in FSX
11:29:00 SimConnect: Event Received: Aircraft Type Changed
11:29:00 GoFlight Connection Starting.....
11:29:00 SimConnect Message Processing Finished
11:29:01 SimConnect Connection Starting.....
11:29:02 GoFlight Connection Started
11:29:02 SimConnect Message Processing Started
11:29:02 SimConnect Connection Started
11:29:02 Aircraft Connection Starting.....
11:29:03 SimConnect: Event Received: Aircraft Loaded/Flight Loaded
11:29:03 SimConnect: Event Received: SIM, 0
11:29:03 SimConnect: Event Received: PAUSE, 0
11:29:03 Aircraft Connection Started
11:29:03 Simconnect Version: 10.0.61259.0
11:29:11 SimConnect: Event Received: SIMSTART, 0
11:29:11 SimConnect: Event Received: SIM, 1
11:29:11 SimConnect: Event Received: SIMSTOP, 0
11:29:11 SimConnect: Event Received: SIM, 0
11:29:30 SimConnect: Event Received: SIMSTART, 0
11:29:30 SimConnect: Event Received: SIM, 1
11:29:31 SimConnect: Exception Received: UNRECOGNIZED_ID
11:29:34 Synchronising Switches & Selectors Complete
The UNRECOGNIZED_ID error can be ignored. A yellow light just signifies an error has been received; only worry if it goes red.
N1 and APP only work if the FMS and AP is configured correctly.
I don't know why your keyboard commands are not working. Do they work without GIT running?
Detective works with all aircraft except the PMDG NGX and 77X as theses planes have full integration of the PMDG SDK's built in.
