FSX/FSX SE registry AppPath entry not found, PMDG options file cannot be checked/updated
Hello,
I receive the above error message whenever I try to open the GoFlight Interface Tool. I didn't receive this error before I installed windows 10 so I'm guessing it has something to do with the latest windows?
The result is that some of the GoFlight buttons works while others do not. Also for some strange reason FSUIPC no longer recognizes any of the Goflight panels but it does see the Throttle quadrant.
Any idea what is going on here? I can program some buttons to work thru the Interface tool, for example Parking Brake and view mode but can not get the PMDG specific events to work.
Jim
Jim
Jim
Jim
Hi Jim,
Sounds like a Win 10 config issue.
Try the things discussed in the thread "Official Windows 10 support?" over at http://support.goflightinc.com/
Also, how do you delete a button assignment in the interace tool.?
Jim
Have you trying uninstalling and reinstalling GIT?
If PMDG NGX/77X set the Button Event to BLANK, for other aircraft use _NO_EVENT.
Jim
Just to test; try renaming the My Document\Goflight Interface Tool directory so GIT starts with no config files.
Thank you Steve
I read this thread and attempted to rename the folder in Docs as suggested. The interesting thing is there is nothing in that folder. But I did rename it, but I still get the same error and of course, my GFMCP Pro isn't working in the PMDG 737.
What should I try next?
Jerry
This message is just a warning. If you are running the P3D version of GIT simply untick Enable for FSX on the Settings tab and click Save.
The old drivers will not stop this message.
http://www.pollypotsoftware.org.uk/support/forum.html#/discussion/271/gfit-lockup-at-start-after-install-new-go-flight/p1
