Partial screen informations
Hello, everyone.
Got here a small issues. I have the old flyengravity cdu version 1.05. Just got the drivers for the pmdg. It works, but if I push the letters buttons to my cdu, I can see them to fsx pmdg cdu but not on my cdu, So I can go through pages in my cdu, but I cannot see everything on mine
Any help?
Can you check you have the very latest version of the NGX installed (version 1.10.6461).
Can you also try increasing the Display Delay Time and tick Never Disconnect CDU.
If none of that works, can you take a photograph for me to look at.
Hello and thank you for the reply.
The nsx version in the latest
I've increased up to 200 and I ticked never disconnect cdu, but nothing.
I have some problem to upload a picture. I sent an email if is ok for you
Thanks for picture. What CPU/Speed are you using and what flight sim are you using?
What processer and speed e.g. Intel i5 and 3.2Ghz.
Can you try:
Setting the Display Delay Time to its lowest value
Change the Standard Text Style to Std
Double check all the baud rates settings match as per the manual.
Do you have 38400 set in your CDU (press EXEC+S together)?
OK. Leave it with me; I'll need to try and recreate the issue or add some code to help track down the problem.
Whilst I'm doing this (it will take a couple of days or so), double check you have set everything as detailed in the manual and try the things I have asked you to change again. Also make sure you have Windows Update up-to-date.
Could you also copy and paste the log from the Log tab after the screen has been updated a few times.
Yes that's all you need. Its a very strange problem but give me a little time to track down what is causing it.
The problem only exists with version 1.0.2.0. I'm withdrawing this version until I find a fix. If you uninstall the version you have and re-download the software it will be version 1.0.1.0 which works correctly.
Indeed, problem solved!! thank you.
I noticed it's a bit slow in responding or change pages, do you think is my pc problem?
