GF-46 and P3d v3
Sir...ive set up the g.i.t (2.1.16.0) with the goflight drivers and p3d v3 ....everything is running great with the pmdg ngx...mcp...efis.
I have even got the aerosoft airbus running with the bespoke events.
the 1 problem I have is the gf-46 is blank,,,it doesn't run,,,nothing shows in the sim.
ive had all the above running great in p3d v2.5 and fsx as well.....I just don't get anything yet from the gf-46 in p3d v3....have you any pointers I can try
Thanks in advance
Andrew
Hi Andrew,
No Simconnect variables are working with version 3 of prepar3d. Lockheed have obviously altered something, that is causing the GIT code that creates the dynamic structure for Simconnect variables to fail. I've tried to track down the problem today without much success.
You'll just have to hang on until I can find a fix.
Thanks for the info
Andrew
After reading your post above I had not used GFIT with p3d v3 until today. I had to manually put an entry into the exe.dll for the go flight driver but after that I loaded the a2a c182 and everything I tested for GFIT worked ok? Is the simconnect problem you referred to only related to certain OS or modules or pmdg?
Terry
Is this something you think LM has to fix or will you be able to fix?
I have sent you another donation for your efforts to get us over to p3d v3.
Terry
New version is now available that fixes Prepar3D version 3 issues.
