Freeze Upon Loading PMDG Aircraft
I have been using the GIT with my MCPro for as long as it has been available. It is a fantastic tool. Last night I had a very strange issue. Upon loading a second flight in P3dv3 the GIT no longer worked. It just hung. I made no changes to my sim except installing an FS2crew update. I uninstalled GIT and the GoFlight software. Reinstalled both with no success. Repaired P3Dv3. Uninstalled and reinstalled both the NGX and 777. No result. The GIT runs when any other plane other than a PMDG plane is running. I am at a loss. It seemed to happen so out of the blue. Any help would be appreciated.
  • I should mention I have the latest version of the software and I have checked my xml.dll to see if any changes were made.
    Did the problems start with the latest version of GIT?
  • No I only updated to the latest when I started having the issue. I was not aware there was a new version until I visited the site and FAQ.
  • Can you read "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" in the FAQ and confirm its still not working.
  • I read that portion of the FAQ and my display is blank. Let me try and explain a little better. I can load the GIT and it loads fine with no issue. I can click on any tab that is not greyed put and change and save settings. When I load P3Dv3 GIT connects with simconnect until I load a PMDG aircraft. Then GIT freezes and becomes unresponsive and the the MCPPro shows a blank displays. In terms of the FAQ I have the latest version of the PMDG software. The PMDG options.dll shows enablebroadcast=1. I am at a loss as to why it happened all of a sudden. I did expieince an BSOD at one point the night before and it seemed to happen after reboot. It made me wonder if the MCPPro malfunctioned and caused a BSOD. I am unsure of why it would cause the GIT software to freeze if that were the case.
  • Check to see if the MCP PRO works with a default aircraft using the Goflight Drivers via GFConfig (set MCP PRO to FS Default) and GFDevP3D. You will need to run Prepar3D and GFDevP3D as administrator.
    Download and install .NET Framework 4.6:
    http://download.microsoft.com/download/C/3/A/C3A5200B-D33C-47E9-9D70-2F7C65DAAD94/NDP46-KB3045557-x86-x64-AllOS-ENU.exe
  • MCP Pro works with default and set to FS Default but I am running W10 and I can not install .NET Framework 4.6.
  • Rename the directory My Documents\Goflight Interface Tool so we can rule out corrupt config files.
  • "Rename the directory My Documents\Goflight Interface Tool so we can rule out corrupt config files"
    That did the trick. Thank you, thank you, thank you, so much for your help. :)
    Mike
  • Hi Mike,
    Glad that's sorted things out.
