Freeze Upon Loading PMDG Aircraft
I have been using the GIT with my MCPro for as long as it has been available. It is a fantastic tool. Last night I had a very strange issue. Upon loading a second flight in P3dv3 the GIT no longer worked. It just hung. I made no changes to my sim except installing an FS2crew update. I uninstalled GIT and the GoFlight software. Reinstalled both with no success. Repaired P3Dv3. Uninstalled and reinstalled both the NGX and 777. No result. The GIT runs when any other plane other than a PMDG plane is running. I am at a loss. It seemed to happen so out of the blue. Any help would be appreciated.
Did the problems start with the latest version of GIT?
Can you read "My MCP PRO or MCP Advanced is not updating its display (just showing zeroes)" in the FAQ and confirm its still not working.
Check to see if the MCP PRO works with a default aircraft using the Goflight Drivers via GFConfig (set MCP PRO to FS Default) and GFDevP3D. You will need to run Prepar3D and GFDevP3D as administrator.
Download and install .NET Framework 4.6:
http://download.microsoft.com/download/C/3/A/C3A5200B-D33C-47E9-9D70-2F7C65DAAD94/NDP46-KB3045557-x86-x64-AllOS-ENU.exe
Rename the directory My Documents\Goflight Interface Tool so we can rule out corrupt config files.
Hi Mike,
Glad that's sorted things out.
