New GFIT
Hello,
I downloaded the latest GFIT 2.1.18 and the displays on the MCPpro only show zeros. They were working with the last version. The MCPpro controls the MCP in the PMDG correctly, just not display on the actual unit. Everything else seems okay.
Terry
  • Hi Terry,
    I've just checked on my system and the NGX and 777 are working fine.
    Go through the steps in the FAQ regarding this issue. If not resolved, let me know which flight sim and PMDG aircraft you are using.
  • Okay, none of the FAQ's were the issue, what I did find is that the .NET program that was updated due to the new software request was not installed properly. A second try and it worked. So you might add make sure the .NET program is installed on the FAQ page.
    Also Go Flight released and software update but when I use it, it locks up the GFIT and I have to use control-alt-delete to close the GFIT. The GFIT program will not work with the update.
    Terry
  • Hi Terry,
    You are the 3rd person to report this so its clearly a problem. I won't be able to resolve this until the end of the week.
