Reference other Bespoke events from within a Bespoke event.
I often find myself doubling up (or triple up and quadruple up) activity in a single control (primarily because I simply don't have enough GoFlight modules to cover every single switch/knob).
Example: turning on/off all DC battery switches with a single switch (Q400 has 4 battery switches).  I realize I could do this with two Bespoke events i.e. "BE_DC_Battery_ALL_ON" and "BE_DC_Battery_ALL_OFF" where I just set the LVars or send events for all the battery events/lvars.
However, I often find myself re-grouping Lvars/events ... as a results I like to break out all the controls individually.  But unfortunately I can't create an "ALL" that would simple just reference my existing individual Bespoke events.
Would love to see implementation of Bespoke's referencing other Bespokes.
Cheers, Rob.
  • That shouldn't be too difficult to do. I'll add it to the development plan.
  • Awesome, thanks Steve.
  • Hi Rob,
    New version uploaded today now supports calling Bespoke Events.
  • HI Steve,
    Wow, thank you!!  Downloaded ... will test out.
    Just finished building my uSimPit ... all good except one of my RP-48's is stuck in a continuous power cycle (tried different USB hubs/ports still stuck in power cycle) ... I just added a new RP-48, my 5th unit and now my oldest RP-48 (black) no longer works.  Is there some limit on the number of RP-48's ... max of 4?  Or do the older RP-48's have some limit of 4?
    Cheers, Rob.
  • Not that I'm aware of. I would check with John at GoFlight though.
  • Will do, give them a call on Monday, email with GF seems to get lost.
    Cheers, Rob.
