Problem installing cdu pmdg
Hello,
recently I bought a new pc and install P3D v3 and the latest version of PMDG.
I have a problem. I Installed the version 1.0.2.0 for the interface but ther is not communication between the cdu. checked the instruction and I add the sdk in the 737 ngx option file as per instruction but nothing.
any help?
If I press exc + s the set up is working.
Any help?
  • edited December 2015
    It looks like the CDU device called "Silicon Labs CP210x USB to UART Bridge" in Device Manager is configured with a different COM port.
    Connect the CDU, find the "Silicon Labs CP210x USB to UART Bridge" in Device Manager and right click on it and select Properties. Make sure all the settings in this device match what is configured in the interface software and the CDU itself.
  • Thank you Steve,indeed it was in another port.
    It works fine now. thank you so much for your help
