GFIT crash on MCP Adv FS DEFAULT button.
Ive just started using GFIT 2.1.18.0 and GFDev.dll v2.2.6.0 against P3D V3.0
I am trying to set the MCP Adv unit to FS DEFAULT mode, but it crashes every time I try this with  "System.NullReferenceException"
As an interim fix, Ive tried to set all the operations for the MCP manually but, not being experienced with GFIT, I cant get that to work either.
Until the crash is fixed, is there any chance you can send a completed FS DEFAULT XML file for the MCP Pro I could import?
  • This version fixes the bug (it will work with P3D even though its the FSX version):
    https://www.dropbox.com/s/2prkq560lweq83s/GoFlightInterfaceTool_Setup_2_1_18_3.zip?dl=0
    Many thanks for your response.
    I have downloaded and installed this version, however it crashes on startup with:
    Problem signature:
      Problem Event Name:    CLR20r3
      Problem Signature 01:    GoFlight Interface Tool.exe
      Problem Signature 02:    2.1.18.3
      Problem Signature 03:    5670615c
      Problem Signature 04:    mscorlib
      Problem Signature 05:    4.6.1055.0
      Problem Signature 06:    563c0eac
      Problem Signature 07:    11a7
      Problem Signature 08:    94
      Problem Signature 09:    System.Windows.Markup.XamlParse
      OS Version:    6.1.7601.2.1.0.256.1
    The previous version (2.1.18.0) starts without issue.
    I have downloaded and testest this latest version and can confirm that it no longer crashes on startup and also, no longer  crashes when setting MCP Adv FS DEFAULT button
    Many thanks
