A320 and GIT
GIT installed and A320 in 2d mode. The detective button greyed out so unable to follow instructions to enable A320. OS is Win7 and P3D V3.1
Lights show. LH Flash red/grey Middle steady Yellow RH flash red/grey.
Help appreciated. Roger Hollands.
Simple words please not very technical
Try the FAQ, 3rd entry down:
http://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/16-installation/70-faq-goflight-interface-tool.html
Hi Roger,
I would upgrade to the latest version of GIT and as per the FAQ entry I mentioned, confirm that the GoFlight Interface Module.dll is loading.
Try running GIT as administrator.
Hi Roger,
It does work with P3D v3. Myself and many people are using it OK. You only need GIT for custom/hidden aircraft functions for complex non standard aircraft. If GFConfig does everything you need then that is the route to go.
If you have only just downloaded the GoFlight drivers then I suspect that has been the problem all along. These needed to be installed along with GIT into the same directory.
This is a known problem on some machines. You need to use these slightly older drivers from GoFlight: https://www.dropbox.com/s/txy23id0n7nqbck/GFConfigSetup_2_25_2.zip?dl=0
