Is it possible to get a copy of GF drivers 2.25.2?
I'm having issues and I hope they will resolve if I go back to the older file.
btw, issue seems to be that of my two GF-166, one locks up.  I have them plugged into a power usb hub (tried direct to computer as well) and when I open the gf config file, I initially see both and can click on each one to highlight the leds.   however if I close out then go back in both are showing but now one doesn't identify.  I just now see a " - " symbol in each lcd display.   Occasionally I'll get an error 43 under device manager.  They use to work fine. Even swapped cables, usb ports, made sure pc doesn't shut them down for power management, etc.  Uninstalled gf interface tool to make sure that wasn't for some reason interfering...I'm at a loss.
