GF MCP & EFIS froze
MY MCP & Efis freezes after I turn any dials.  If I use the  mcp on the PMDG, the digits turn on the GF MCP, but not if I use the dials on the GFMCP.  I have tried reveting to GF config 2.25.1, but still no joy  I have GIT 2.1.16.0.  Any other ideas?
George
  • Hi George,
    When did the problem start and what changed on your system?
  • It only happens on the PMDG T7.  It works fine on the defaults and the Level D.  So I don't know if its a T7  or GIT issue, since I only use the GIT on the T7.
    George
  • I think I found the problem.  In the GF config, I had it set for the T7, but under the MCP pro, I had it set to the Level D and not compatible aircraft.
    George
