GF MCP & EFIS froze
MY MCP & Efis freezes after I turn any dials. If I use the mcp on the PMDG, the digits turn on the GF MCP, but not if I use the dials on the GFMCP. I have tried reveting to GF config 2.25.1, but still no joy I have GIT 2.1.16.0. Any other ideas?
George
Hi George,
When did the problem start and what changed on your system?
It only happens on the PMDG T7. It works fine on the defaults and the Level D. So I don't know if its a T7 or GIT issue, since I only use the GIT on the T7.
George
I think I found the problem. In the GF config, I had it set for the T7, but under the MCP pro, I had it set to the Level D and not compatible aircraft.
George
