ADF for F.O. .. i possible?
My name is Duccio, I am an administrator of VV (www.volovirtuale.com) and I would like to discuss with You about same problems I have to fix about ADF2 and GF166 wirh PMDG, because at the moment in not possibleto configure by GFCONFIG.
I have tried to write to FG support but I am waiting for an answer
this is my last video posted on Youtube, I will be glad if You ll post a comment.
  • edited November -1
    Hi Duccio,
    The interface does not support the NGX and GF166's at the moment. It is however in the development plan.
    thx Steve for the faster replay, i will wait.....
    another question, often I do not have on the MCP pro the DIGIT, encoders are working fine, but nothing is showed and the only way to have it working is restart FSX, I suspect the all my connection problems are caused by SIMCONNECT, Any suggestion?
    Hi Duccio,
    I'm not sure what you mean.
    Dear Steve
    often when I started the GFPMDGINTERFACE i have only 00000 digits in the MCP DISPLAY and there is no way to have it working, i must restar FSX.
    other question:
    I have found people used th eold Offset (ADF2 Fs2004) to drive the ADF2 in FSX ? I have tried to read the GFDISPLAY, but before start to study i'd like to know what do u think about it.
    thx in advanced
    Hi Duccio,
    There are certain conditions in the PMDG SDK that cause the SDK to stop transmitting variable data. Its normally when you restart a flight or load another NGX model when an NGX was previously loaded. PMDG are aware of this and say nothing can be done about it. It manifests itself as none of the displays and led's updating.
    The ADF2 offset may work, but you won't be able to do it in my software until I have fully migrated the NGX to the Goflight Interface Tool. You could try using FSUIPC though.
