SOLVED! - GIT 2.1.19.5 lockup with GF 2.26.1
I know several folks were having issues when using both GF 2.26.1 and more recent GITs - see discussion here.
After installing Steve's latest 2.1.19.5 and using current GF 2.26.1, I had the same GIT lockup problem.  I was also having a power cycle issue (LEDs on my RP48 or P8 or T8 would continuously do follower the leader lights).
So I disconnected All my USB devices and started plugging them back in one at a time (very tedious) and then I'd bring up GIT which to my surprise was working (not locked up) ... so I repeated the process checking GIT after each device plug in, and bingo when I plugged in my MESM, GIT locked up and the power cycle started.
I'll pass this info along to GoFlight on Monday IF I can get a hold of them.  But if others have this issue, try disconnecting your MESM.  Or if it's just a device issue, try the diagnostic steps I did above to isolate the problem.
Cheers, Rob.
  • Nice find. I don't normally have my MESM attached so your findings stack up. I'll be able to debug at what point it fails now. Thanks Rob!
  • Let me know what you find out Steve ... it's odd that my power cycle issue also stopped when I disconnected the MESM.
    The MESM does seem to show up just fine in GFConfig, but for now I'll keep it disconnected so my other GF modules don't power cycle continuously.
    If you have any line to GF, would love to get their thoughts on the power cycle issue.
    Cheers, Rob.
