Running 2 interfaces together.
Hi. I have your GoFlight MCP Pro interface software running and was wondering will I be OK to also have the CDU interface running at the same time?? Thanks in advance
    Yes they do work fine together.
  • Many thanks Steve. On a side note, I've just received my second hand CDU with no power supply, only the lead with bare ends. Any ideas?? Thanks for any help.
    Regards. Keith Sandford.
  • A replacement charger will need to output 12v DC 1.0A. The other cable is a standard USB cable.
  • Thanks very much. I'm just about to purchase your driver, do I need to install any additional drivers either beforehand, or after? Thanks
  • No. When the CDU is connected it will install itself as virtual serial port (Silicon Labs CP210x USB to UART Bridge) and Windows has always picked this up automatically for me.
  • Ok that's good to know. Thank you.
