How can I switch off the gf166 on battery power off?
Hello and thank you for your wonderfull software. I am using default Beech Baron with three GF166 panels. I wonder how can I make them switch off all displays and LEDs when the plane is powered down to cold and dark state. I am aiming to have everyhing dark in my cockpit when there is no power available.
Is it possible? That is the only task I need the GIT for, otherwise I am happy with native Goflight driver.
Best regards,
Pavel Brodsky
It does have the facility: http://www.pollypotsoftware.org.uk/support/user-guide/user-guide-git/19-operating/33-aircraft-power.html
However, I suspect that if you are using GoFlight drivers to drive the GF166's there is a good chance that they will overwrite the "blanking" that GIT does.
