CDU delay worse than ever. However.
I was getting bad delays between clicking a button and the action being carried out on both CDU's (hardware and software). However, the CDU disconnected and reconnected and from then it was fine. But, why did it disconnect in the first place and how can I fix this please? It's driving me mad.
  • It's only reset once, the rest of the time I'm getting long delays. The baud rates are set the same and I'm USB 2.
  • Ok the CDU has just turned itself off and then 2 secs later, back on and all is working correctly. Does this make any sense at all? Can I force a disconnect and reconnect myself to get things working properly?
  • After more trial and errors I have found a Half-baked solution to the time taken from key-press to the CDU responding, of between 5 to 10 seconds. If you press "save settings" the CDU turns off and back on and there is no longer a time delay. However, it does not last and you find yourself having to press "save settings" again to restore the delay. What is the answer to this because as it stands I'm sending the bloody CDU back to the shop.
  • I have same problems with version one. When I push something I have to wait 5 10 seconds that is shows at display also change the pages
  • Sorry for the delay in responding, I've been ill.
    I believe I have found the bug and fixed it. Version 1.0.3.0 of the Interface will be downloadable in around 5 minutes. Let me know how you get on with it.
  • Fantastic news. Thank you.
  • Glad you're back on your feet, Steve. Do we uninstall old version before installing new version?
  • Probably best to do that.
  • This new version works great.
    Many thanks.
    Ad
