2.0.386.0
Downloaded this morning. The GF_MCP has gone back to one of the old problems.
No digits and LED's working, buttons and rotaries are ok.
Gone back to 2.0.383.0 and all is ok.
Trevor
  • edited November -1
    Hi Trevor,
    Was there any error messages in the log?
    Sorry Steve never looked.
    Hi Trevor,
    Could you try again. Although I can mimic the MCP on my PC, I don't actually own one so I am always flying blind with that particular device.
    Ok Steve,
    Stuck it back in, have the same message in the log as I got the previous time they went walkabout.
    Bunch of Simconnect exception received: event_ID_Duplicate's   then the line
    Simconnect:exception received: Name_Unrecognised
    Next and last line normal.
    Synchronising switches and Selectors complete
    All units work  except for the GF-MCP, digits and led's.
    Trevor
    Hey Steve,
    The program is working great, I have finally starting to understand the bespoke commands and the use of the detective and now have gotten all my CS 707, and CS727 to work the the go-flight equipment, your a genius.
    I do have a 2 small items..
    1. When I go to clear out a module (hitting the red X button) it clears out the whole program. So if I clear out the P8 module all the commands on all the other modules get cleared out also, all the data is wiped for that aircraft.
    2. For some reason I have programmed the CS 727 and after I have done the work I hit save settings. When I start up FSX and the interface, the 727 data I programmed is not there. All the other aircraft data is there just the 727 is gone. When I look into the config folder I can see that CS 727 data has been saved, it is just not getting recalled.
    1 more question, since I have the CS 727 series of aircraft, I was hoping to save the data to a short name such as CS 727 as opposed to CS 727-200. This way I can have the same data work with the CS 727-100 which uses all the same switches and codes as the -200. Is there a way to make them work without having to write code for the -200 and then again for the -100???
    Thanks again for the great program..
    Terry
    Hi Terry,
    Point 1) I have just tested this and can't replicate the behaviour. Can you detail all the steps you take including which devices you use and also send me over your config file.
    Point 2) This may be a short name issue. Some aircraft add livery names at the end of their designation and the Interface will see this as a different aircraft. The answer to this and the final question is to load up the aircraft you actually used to create the config. Go into the Settings tab and change the aircraft name e.g. from "CS 727-200" to just "CS 727", then click the OK button.
    Let me know how you get on.
    Okay I think I found the problem and so far it is working great, I need to program one set on input to the CS727-200 and then program another set for the CS727-100 and now all work..
    I have found that on an certain situations the beacon light and the nav light for the CS727 series fails to stay saved. When I re-open the detective the Bspoke switch control is still there but the Light_Nav and Light_Beacon have been removed, If I re-add them in the Bspoke the adding of the Light_nav or the Light_beacon get added but there is a space between the switch control and the Light_nav or Light_beacon. Removing the space get the lights to work properly but when I close the program and the flight sim and re-open it up the same 2 light_nav and Light_beacon are gone again. The space in the Bspoke is from where the Light_nav or Beacon was, just nothing is saved. Everything else is saved fine.
    Terry
  • edited May 2013
    Hi Terry,
    Send me over your config file or export the bespoke events and config for those two aircraft models and I'll take a look.
