Simconnect/FSX
Why is the Simconnect /FSX button yellow. Should it be Green like the other two(GOFlight and Aircraft columns
It just means an error from Simconnect has been received - you can check what it is in the log. If everything is working OK you can ignore it, eventually it will go green.
http://www.howtogeek.com/228467/how-to-make-a-program-run-at-startup-on-any-computer/
Frank
You can add it to exe.xml in that case.
